Re: Lubrication
The "sump" is the area around the crankshaft. When this area is used to store lubricant that is not in the pressurized lube cycle it is called a wet sump.
In a dry sump system the oil not in circulation is stored in a seperate oil tank.
Many older motorcycles, radial aircraft engines and others use a dry sump system.
Four stroke outboards run fine on 10% ethanol.
