Re: lubricants, etc...
Dhadley,<br />The Clymer's manual said to use needle bearing grease on the shaft. I don't know why except that needle bearing grese won't dissolve when gas hits it? Oh well, I know from working on my truck under the supervision of a good mechanic friend that there's the "right" way a manual describes and then there's the way professionals who work on these things day in and day out do it.I had suspected that it didn't take 6 different OMC brand lubricants and sealers to change a water pump. Just good grease and gasket sealer? Good. Any recommended brands of either and what do you reccommend for gearcase lube (synthetic, hi-vis, etc...).<br />Thanks for your help.
