Re: LU Question 1975 70hp Evenrude
You should have 4 bolts on the outside, one underneath the trim tab plate and one underneath just behind the trim tab. Make sure to use OMC gasket sealer on these bolts and the water impeller housing when you reinstall, prevents the bolts from sticking from corosion next time you have to remove them and makes sure the water housing is sealed.
Thanks
