eavega
- Apr 29, 2008
- 1,377
I have a 68 20 HP Johnson, which I have raised a few issues on here. I have the motor running, and am currently trying to troubleshoot an issue with it not cooling, but now I have run into something else and need some guidance here, too.
I took it out on the lake yesterday for the first time. It ran for a total of about 7 minutes over two hour's time (ran about 3 min, started getting very hot, shut it off, waited for it to cool, then 3 min back to the ramp). I drained the LU oil, and sure enough, what was nice clean LU oil is now greyish-green goo, which I assume is water in the oil. When I filled the oil, I replaced the vent/fill screw washers, so I am going to assume a bad seal somewhere.
I have not pressure tested the LU yet, that is going to be tonight, but I am just trying to get ahead of the game. If I am going to have to crack the gearcase (which I suspect I am) and replace the seals, I just wanted to know how involved this job is? I have read through the procedure in the service manual, and it actually sounds rather involved, plus there is need for three special tools to get this done (seal puller, bushing mandrel, and bushing punch). I can't find a price anywhere for these tools, except for the seal puler; its an aftermarket, and its almost $80. I'm wondering if I should punt on this occasion and get a marine shop to service the lower unit. If the one tool is $80, a seal kit is about $20, what will the entire process set me back?
Any guidance is deeply appreciated. This motor is so close to running well, and in the short time I had it on the back of the boat it really performed outstanding, so I really don't want to give up on this one and have to start over.
Rgds
Eric
Rgds
Eric
