Captain Caveman
- Mar 1, 2005
- 1,028
No matter what I did, I couldn't get the fish arches back so I did the factory reset procedure in the manual. The unit was working fine (except for not showing fish arches) prior to the reset but now doesn't work. It reset to the factory settings. I turned off the 'Simulator Mode' but as soon as I do that, it either shows unrealistic depth readings and no graph or it just shows nothing. If I turn the unit off and then back on, it automatically goes back into simulator mode. The manual says that means that there is a transducer or cable issue.
I checked after pulling my boat out of the water and it all is in good shape. The whole boat and unit is only 1 year old. The more interesting thing is that it stopped working in the middle of the lake. One minute it's giving accurate readings, then I do a reset, and now it doesn't work correctly. I find it hard to believe that the transducer or cable died or changed status in the middle of the lake.
Any thoughts?
Any thoughts?
