X49 that came with used boat. Downloaded manual but still having a hard time figuring out the wires. I can pull them to trace but thought someone hear can probably save me the trouble.<br /><br />Looking at back of unit it has two connections. One on the left is single wire and appears to be power. Right side connector has two wires that run down into the deck. A single wire comes back out and goes to the transducer mounted on the trolling motor.<br /><br />Am I correct that the left connector is power? What is the right side connection, transducer and ?<br /><br />Thanks for the assist!
