Lowrance x102 broken
pointblank1000
Comes on and shows 0.0 ft (all the time) and when I go to turn it off (holding the menu button down), it does not shut down.
Really not worth sending out to have repaired so, if I cracked it open could I fix it? Maybe it's an internal fuse or burned wire????
What do you think? It's a 2005.
Thalasso
Re: Lowrance x102 broken
Junk it. You won't be able to fix it. Circuit board is probably cracked
