Lowrance hds-5
air604
I just purchased a Lowrance HDS-5 and the Structure Scan and was looking for information. I have a Ranger 520vx with a Lowrance x135 with a shoot thru hull transducer. The question is, can I use that transducer for the HDS-5. I am mounting the Structure Scan transducer on the step and really do not want to drill any more holes in my boat. Any info would be great.
Re: Lowrance hds-5
yes, you can used the same 2d transducer, I do recommend that do change out your pwr cord, because you will want to connect the yellow from the lss-1 to yellow from pwr cord from hds unit.
