lowrance gps module waterproof?
gator79
I turned on my lowrance global map 3200 and it stated the gps module was not responding. I took it loose to check the wire conector and heard water sloshing inside the antenna module. seems to me this antenna should be waterproof. it is mounted on my radar arch. looks like a new one cost $250.00. it is only 14 months old. anyone had this problem before?
imported_JD__
Re: lowrance gps module waterproof?
gator79,<br />It should be water proof. Can't say for sure but if you have documentation as to the receiver's age, I'll bet Lowrance will take care of you.<br />JD
