I have a Lowrance Elite FS 9, I've just used it a few times now. The problem that I'm having is that I'm powering it on the same three 36 volt set of batteries that is running my trolling motor. Sometimes when I increase or lower the power on my trolling motor it will turn the screen on or off or reduce the brightness. I'm just wondering if there is a setting that will reduce this? Or is there any other ways to eliminate these interference issues? If not will I have to run the Elite FS 9 on a separate battery to fix this issue? I'm not sure why this happened recently because the first 3 days I ran it on the same 36 volt battery system and didn't have those interference problems. So I'm not sure why its now doing it. I am using a small set of battery clamps to connect it to the battery, I don't think this is the problem since I've been using them on another Lowrance fish finder for over 17 years but I'm not sure.
I'm considering getting one of the smaller 4 or 5 inch Duracell 12v batteries. If it will run it for 12 hours consecutively or longer, I'm not sure which one yet. Anyone know which one in that size range will run it for that long?
