Lowrance 3500c vs. Garmin 172c Chartplotters
FreeBeeTony
Looking at these two units.<br /><br />I am leaning towards the Lowrance, has a larger display with more resolution. The Lowrance has an option called Mapcreate where you can program your own chips. Anyone with any experience here? I think the performance is similar otherwise.<br /><br />Any/all suggestions/opinions are welcome.<br />Seems like Garmin is the choice for GPS but Lowrance has a good reputation for marine electronics as well.
fishingdan
Re: Lowrance 3500c vs. Garmin 172c Chartplotters
I agree with you that the Lowrance 3500c has a better screen than the Garmin 172c. The Garmin gives you a choice for internal or external antenna. The Lowrance is only external. If your boat is the one pictured, you will probably run the external in either case. <br /><br />The Lowrance has a better base map than the Garmin.<br /><br />The Garmin used Garmin maps only. The Lowrance uses Lowrance or Navionics maps. I think the Garmin bluecharts are roughly equal to the Navionics maps for most boaters. The Lowrance NauticPath maps are inexpensive, but not as detailed. <br /><br />The mapcreate software is useful only for enhancing the base map with land based detail and add some navigation aids/hazards to the coastal water of the base map. If you want depth contours, tide data, etc, you will need the external map card (navionics or nauticpath). The nauticpath and navionics screens cannot be seen on your pc. <br /><br />Transfering waypoints, tracks, etc. from either unit to your pc is easy. Lowrance is probably easier since you simply need to pull the memory card out and put it in your pc. <br /><br />I think either is fine. On the east coast, Garmin has a well deserved reputation for quality and good customer service.<br /><br />Down south and in the midwest, the same can be said for lowrance.
dingbat
Lowrance has a habit of rushing stuff to market here as of late and they have a lot of issues right now. A lot of people around here have simply given on them an went to other suppliers.
FreeBeeTony
Anything specific regarding the 3500c?
FreeBeeTony
Any other opinions?
gss036
If money is an issue, Cabela's has the 176C Chart plotter on sale for around $450, good price and you have the option of the BlueChart system. I have used one for the past 3 years and it has worked great.
FreeBeeTony
I think the 176c is an older unit compared to the other 2. I can probably fine the 3500c or the 172c for close to the same price.<br /><br />Thanks for the input though..............
Trent
I have a 178C that I like but when the sun is to your back I can hardly see the display. Also the screen is too small for me. I love the unit at night!
tommays
the 192C is selling for 699 right now and has a full set of blue charts built in which its a very good price if you need to buy charts<br /><br /><br />tommays
phinsup
I just returned my 3500c for a garmin 192c, the only thing that kept me from buying the garmin was the expense of the maps, the new 2006 garmins have the maps pre-loaded, nothing to buy.<br /><br />I was initially impressed with the 3500c, I had it for about 4 months, little less actually and it crapped out on me. Went to the boat store swapped the antenna, still didn't work so we decided it was in the unit so i traded for the new garmin! :D
phinsup
Oh and I grady white overnighter, i bought the internal antenna and it works fine through the plastic and bimini.
FreeBeeTony
I compared the 2 displays today......<br /><br />The Lowrance definitly has a better display, more resolution.<br /><br />However, the Garmin/Bluechart chart displays the shallow areas in blue, where the Lowrance/Navionics chart does not. The Garmin/Bluechrt makes it easier to see the shallow areas, but I really liked the Lowrance resolution better.<br /><br />Wish I could have the best of both worlds....
