Re: Lower Unit
Make a gizmo with a barbed pipe thread fitting, a tee, a pressure gauge (0-30psi works well), and some tubing and tie wraps or tiny hose clamps. Threaded fitting goes into the open hole, gauge attaches to the tee. Hook the remaining open end of the tubing to a bicycle pump. Bike pump is easier to control the pressure. A valve between the pump and the rest of the setup is nice, though vise grips might work if you can't come up with something better. Medium sized metal hemostats are better than the vise grips if you can find them. I like to slip some tubing over the jaws to keep them from chewing up the tubing to be clamped if the jaws are not the smooth kind. The cheap plastic tubing hemostat clamps I do not trust for that much pressure, especially with thicker tubing. Make sure the test rig does not itself leak before testing the lower unit.
