Re: Lower Unit
All you have to do if the tilt lock won't work tilt the motor all the way up and stick a 2"x2" inbetween the motor and mount that will hold it up till the cows come home. I used to do that on a 50 I had when pulling on trailer because the lock would turn loose with the bouncing. Hope this helps.
