lower unit
merc1974
would anyone be able to tell me what part I'm looking at in my lower unit with the arrows on attached photos and should it be so banged up also can I pressure wash out the lower unit ? 342.jpg346.jpg345.jpg352.jpg
Re: lower unit
That is part of the reverse lock mechanism.----When it shifts to reverse it locks the motor down so it does not kick up.----------If mechanisms are not operating smoothly then damage results.
oldman570
Re: lower unit
Defiantly the reverse lock cam, that has been used very much,
JMO
Oldman570
merc1974
Re: lower unit
Thankyou Racerone can i just replace that top piece and what is the part name?:)
merc1974
Re: lower unit
Thanks oldman570 and with this type of motor when shifting should it be quick swift into reverse or slow shift into reverse and forward as it tends to grind when shifting into reverse.
Re: lower unit
Always shift with a quick firm motion !-----Both forward and reverse.
Chris1956
Re: lower unit
Merc calls that beat up plastic piece a cam. The reverse lock rod is supposed to move up and down following the contours of the cam, and the reverse lock hooks grab a rod locking the motor in the vertical position. When shifter to forward, the lock is released.
carholme
Re: lower unit
If this engine is still the 402 you have discussed in previous threads, here is the parts list for s/n 7038943:
MERC 402 - Mercury, Mercruiser, Force, etc. Parts Lookup
Under GEAR HOUSING ASSEMBLY, COMPLETE (PAGE 1), see item 43, 43308T1 CAM. Click on the picture of the cam and it will blow it up for you so you can see what a new one looks like.
Gerry
