heygoody02
- Jun 10, 2004
- 5
2000 Johnson 130 HP V4. Hooked the muffs up the other day and noticed water streaming out of the joint between the lower unit and mid-section. Didn't think much of it until I started up the motor and now had water pouring from this area. Water was clear and the pee hole flow looked normal. Several weeks ago I did hit hard bottom with the prop at idle speed. What sould I be looking for? Water pump damage ? Seal? Thanks.
