lower unit swap
ddaigle
can a 1970 v-4 hydroelectric lower unit be installed on a same era 3 cylinder motor and if not are some of the parts interchangeable? thanks
phatmanmike
Re: lower unit swap
without knowing what exact year and horspower.. it woul be virtually impossible to tell.....but im gonna look it up in my manuals anyway... ill let ya know...ps did you see it on ebay, in the ebay motors/outboard engine and parts section....<br />#2460154947
ddaigle
Re: lower unit swap
Phatman, i was talking about the one you said you have. just trying to make sure it would work.
Chinewalker
Re: lower unit swap
They're different units. Driveshafts are different, castings are different...<br />- Scott
ledgefinder
Ensign
Re: lower unit swap
Scott's right - the V4 & I3 LUs don't interchange, though they look identical on 1st glance.
ddaigle
Re: lower unit swap
Many thanks, the knowledge and info on this site astounds me. Guess i will have to pull my lu apart and hope for the best.
phatmanmike
Re: lower unit swap
if the problem is simply that ddaigles shift selonods went crap-o-lah on him, can he use the selonoids from my 4 cyl gear case??????
