Lower unit stuck
wavebuster58
In attemoting to remove the lower unit from a '76 55hp Evinrude, I have come to the conclusion that I need serious help. I have removed the four mounting bolts, the trim tab, the bolt underneath the trim tab, and the bolt under the lower carb that holds the shift rod. The lower unit will pivot about 2 inches each way at the tail so I know its lose, but It won't drop down at all. I've tried wedging it off and hammering on it. I have a Seloc manual and it looks like I've done all that's required. Everyone I've talked to says it should drop right off. Even an Evinrude mechanic!
Hooty
Re: Lower unit stuck
There are seven bolts to remove. Sounds like you missed the one in front of the trim tab.<br /><br />c/6<br />Hooty
wavebuster58
Its been a while since I removed the bolts but I did get the one after removing the trim tab. I guess there are six exposed and one under the trim tab. I've removed them all. It wouldn't pivot if I hadn't would it?
wavebuster58
It pivots in a straight line with the drive shaft. From all I can tell it's seized into the crankshaft.
ledgefinder
Ensign
Hooty's right, there are 7 (I ran out to the garage to check). So is does sound like you're stuck at the crank/driveshaft spline junction. Were this a Merc board, we'd be used to this situation (OMCs have better corrosion control than anyone). <br /><br />Here's the best solutions, drawing partly from experience working with Mercs. If the motor's running, I think the best solution is to loosen the lower unit bolts about a centimeter, then back the boat into the water with the trailer strap on, start the motor, and run it in forward and reverse a few times. I haven't had this fail to loosen the driveshaft spline on an OMC yet. Basically the gearbox housing, pushing back and forth by the prop, creates a torque (moment) on the exhaust housing, which becomes a tension on the driveshaft spline joint. Given the heat, vibration and impulse of running, the joint separates.<br /><br />If that doesn't work or if the motor isn't running, the Merc guys recommend loosening the bolts/nuts at the exhaust housing/powerhead junction, then "gently" dropping the combined apparatus from about 6" onto a rug. I can verify that this did work on a Merc 85hp. Examine the splines afterward and see how much damage you've done. You may not want to attempt to run to the Bahamas with this motor now. <br /><br />When you put it back together, obviously you want to grease the spline and run an O-ring to keep saltwater out. OMC gasket compound on the bolts holding the lower unit on, and on the mating surfaces, is also a good idea.
wavebuster58
Just wanted to let you guys know there are only five bolts including the one under the trim tab. I haven't tried ledgefinders ideas yet but thats next. Thank you both for your input. Let me know if you have any more ideas.
ledgefinder
Ensign
Just wanted to mention the Merc guys are holding the motor parallel to the floor (or soft rug) before dropping it - not standing the motor up & dropping it on the skeg. Mercs have a pretty strong circumferential rail around the bottom cowling, which makes it easier to do this. I'm worried you may bend the bottom cowling (engine pan) on your OMC - I'd take it easy at first anyway.<br /><br />There should be another bolt in front of the trim tab (not under it). Isn't there a recess there for it? <br /><br />Does sound like there all out though, if you can pivot it. It's probably the body of the water pump & the water pipes that holding it from pivoting further, so take it easy.
OBJ
Wavebuster....you posted that it pivots in a straight line with the drive shaft. If you can get the thing in gear so that the drive shaft would turn the flywheel as you pivot it. Hold the flywheel so it don't move. Then pivot the lower unit counterclock wise and back and forth. This might break up the crud thats' holding it and let it drop. Just a shot to take.
wavebuster58
Hey fellas, while I was off work this weekend I tried the suggestion of putting it in the water on the trailer with the bolts all loose and shifting it into forward and reverse to break it loose. Apparently its stuck on there better than that. I took it to a friends house and he suggested cutting the drive shaft with a torch to get it off and then drilling and tapping the end stuck in the crankshaft, then removing the stub end with a slide hammer. My question is do you think after doing this that the crankshaft would still be good? The motor runs fine right now but I doubt that the water pump impeller has ever been changed. Do you think I should just run it till it pukes then get a new motor? Considering the cost of a new drive and crank shaft I'm wondering if this wouldn't be best.<br /><br />Thanks again for any input.<br />Vic
ledgefinder
Ensign
I'm surprised that didn't work - are you sure all the bolts are out? There should be one above the propeller, in front of the trim tab.<br /><br />I'd run it the way it is, if the alternative is cutting up the midsection with a torch. The OMC impeller's are pretty good compared to Mercs. Make sure your overheat horn is working in your control box (ground the lead wire under the motor's hood to check). You can rig a telltale, or even a water pressure gauge, if you want to be sure everything's OK.
