Hello people,need some help here I have a 1990 Evinrude 25 hp.I hadnt ran it in 2 years ,last weekend decided to start her up and exercise her a bit.I mixed up a gallon of fresh gas and started her up she was a bit stubborn but did start with quite a bit of smoke.She was running ruff for about 20 to 30 seconds and i did not see any water coming from the pisser so i cut her off,i re-adjusted the water muffs and started it again,ran for about 20 seconds still no water.I decided the waterpump must be shot.I have replaced the pump on this motor before,probably around ten years ago.So i began to remove the lower unit to do the job but it will not drop down all the bolts are out and the shift linkage seperated I can rotate the prop side of the l/u left to right slightly but the joint has not seperated at all,im not sure but i think the drive shaft may be stuck/corroded to the crank.Any idea's on breaking this loose would be greatly appreciated.
