Re: Lower Unit Stuck 200hp Johnson 1995
Get a couple of packs of wood framing shims from a lumber yard and work them in, opposing each other. Have them front and back so that you bring the unit down evenly.
If the motor has been sitting very long, you might have better luck if you button it back up and run the boat hard. That often will break the shaft free if rust is the problem.
Because of the heat and high friction, anti-seize products don't usually help. BRP/OMC Moly Lube will do the job: part #175356 in a 3.5 oz. tube.
If you put too much of any lubricant on the driveshaft, especially at the top, the driveshaft can hydraulically seize.
