lower unit slack
raymondridge
I have a 1977 85 evinrude. I removed the lower unit to replace the water pump and noticed that the drive shaft has about 1/3 turn of slack before propeller moves. Is this normal? How much is considered ok. If 1/3 is too much what does it take to fix this. Thanks in advance.
Paul Moir
Re: lower unit slack
That's normal. You're just feeling the free play before the ears engage.<br /><br />Here's a typical outboard forward gear and the "clutch dog" which drives the propshaft:<br />
<br />The little ears sticking out of the clutch engage with the lobes just inside the gear teeth. That is to say, the clutch dog ears fit into the wide space between the centre of the gear (where the propshaft goes through) and the gear's teeth. Then they strike the lobes.<br />The gear is always spinning when the engine is running, but it spins freely on the prop shaft. The clutch dog on the other hand is bound to the shaft, so when it engages the gear, the propshaft spins. <br />If you look closely, you can see where one of the ears on the clutch dog has been damaged by easing the engine into gear.
gatorred
I have seen gear's fixed with milling machine had bit in it to claen up bur's,file can work to slop on shaft bigger has more slop alowed when it start's jumping in and out of gear you got problem's then.
raymondridge
Thanks again Folks,<br /> The pictures really explained it all. I am blown away that I get almost instant answers with pictures. Thanks
