dancamp007
- Nov 2, 2005
- 22
Hi. When I drained the gearcase oil I noticed the blue salt-away solution had accumulated inside and the oil itself was very milky. On retrospect, I realize I was probably responsible for the blue fluid as I plugged up the little drain holes while I was filled the thermostat hole with salt-away to clean out the water jackets and this proabably caused the problem. But, being the jerk I am, I didn't realize that and so when I did a air pressure test I think I may have blown a hole in the shift shaft boot as I hear air coming out of that area, so I wanted to remove the shift shaft boot and unscrewed the phillups screw, but it wouldn't pop out. So I pulled on the boot with no success. Then I pulled on the shaft itself and it seems to have pulled out about a half inch, but the that was all and the boot still wouldn't come out. Now I just want to get the shaft back in the original location and put it all back together, but the shaft doesn't seem to want to go back down that half inch. I've tried rocking the gears a little back and forth without success. The big virticl drive shaft doesn't seem to turn at all with little force, though the propeller shaft will turn a little. Please tell me what I have to do to change the shift shaft boot and get that shift shaft back in it's original position. My Clymer Yamaha ship manual doesn't tell me how to get the shift shaft back in place.<br />Thank you for any help on this problem.
