Re: Lower unit seals
Hi Medic<br />I do not know which manual you have, but I am sure that it covers removing and installing each seal in your L/U as a step in the over-all disassembly and reassembly. This means you will have to read the entire chapter. To answer your question, Yes you will have to pretty much disassemble the entire gear case. At least remove both shafts. As DHP states the toughest part of the job may be disassembly. This can range from a cake walk to the mutha of all pains. Of course your manual is going to show you pictures of a fella working on a brand new unit, using the latest in special tools. Only you know if you can do the job. Can you fab your own special tool if needed? Do you have access to a slide hammer or the correct type pullers? This is how I make this decision. What is the value of the broken thing if repaired? What will it cost to have it repaired? Do I have enough time to make repairs before I absolutely need the thing. Remember it takes at least twice as much time to make repairs at home. Then I figure what do I have to loose, the darn thing is already broke, go ahead and try, it will be a learning expirence.
