Lower Unit seal on a 1995 Johnson 40hp
doug99uk
Newbie Warning; this is my first post!<br /><br />What type of seal if any exists between the lower unit and the upper engine section?<br />I am planning to take off the lower unit to replace the water pump, this will be my first time! I am mechanically competent (cars and motorcycles) and have purchased a Clymer manual.<br />Just thought I would ask the simple question here rather than wait until I drop the lower unit to find out the answer, and save time by obtaining any parts.<br />The engine number is; BJ40TLE0D.<br /><br />P.S. I have been reading/searching on seals etc. but my query is really if any seal exists at this point, perhaps not if the water pump resides in some kind of aperture in this area??<br /><br />Thankyou for any help, much appreciated.<br /><br />Doug.
R.Johnson
Re: Lower Unit seal on a 1995 Johnson 40hp
There is no gasket between the gear case, and exhaust housing. If you get the complete water pump kit, it will have every thing you need. Also get a small can of OMC gasket sealer.
