Re: Lower unit seal kit
Mike,
I forgot to mention to make sure those drain and vent plugs are in good and tight. If they are the slotted type sometimes you can't get a real good grip on the screwdriver due to the position it is in, and possible gear lube on hands. It is possible (and what I do) to use a cresent wrench on the screwdriver close to the handle, to give it a bit of a snug once hand tight. BUT obviously don't go nuts with it I usually get it as hand tight as possible then just a bit more with the wrench on. If they are the allen type you can get the correct size that fits on a ratchet and do it that way. I believe the plugs are steel while the case is mag or alum. Definately don't want to strip them out so use good judgement if you use a wrench or ratchet. I have heard of people needing impact drivers to remove them so They can take a bit of torque. Drain with unit all the way down,screw pump hose into lower hole, pump until a bit comes out vent hole, insert vent plug, remove pump hose, have drain plug handy, quickly insert drain plug, tighten both as per above. Have some cardboard under skeg as there is always some that leaks out when inserting drain plug.
