Lower unit removal water pump impeller replacement 1991 90hp
Bearcat_w
I'm replacing the impeller on a 1991 90 hp. (906X91A). When removing the lower unit it splits about a 1/2" then hangs up. Do I have to disconnect the shift rod or is there something else that is holding it up?
Jiggz
Definitely need to disconnect the lower and upper shift rod. Additionally, make sure you dismount the exhaust snout and there should be another bolt underneath it that needs to be removed also.
fhhuber
Might mean the trim tab, under the antiventilation plate, behind the prop.
MARK THE ANGLE the trim tab is set for before taking it off to get to the bolt under it.
(You probably already got that off if the lower unit is dropped 1/2 inch)
Because you already dropped it partway with the shift linkage connected you will have issues putting it back together.
Once its apart, hand move the shift linkage to find neutral.
Measure the shift rod from where it enters the gearcase to top. Write this down. You need +/- 1/32 inch or 1mm accuracy. (no those are not equal)
When you put it back together you need the upper unit gear linkages set for neutral. the shaft has to be screwed back in to the correct amount. (even if you don't take it out, they tend to twist 3 or 4 turns while you change impeller)
jerryjerry05
If it drops 1/2" then the snout's already off and that bolt is out.
There is a connection at the front/ top of the drive.
Small cotter pin and a pin with tiny hole for the cotter pin.
​This comes out.
The drive drops down.
​There should be no need for finding N or F or anything else.
These just go straight back in.
​The shift rod coupler, make sure it aligns and it should just go right back where it was.
​If you've messed with the shift rod?? just screw it back in and maybe 1/2 turn out to align the holes.
​IF? you don't mess with stuff it should just go right back in and no adjustment needed.
