I'm in the process of changing the water pump with the kit, so far I have remove the lower unit by removing the intake screen and unscrew the upper nut to drop the lower unit , there are two nut in the intake screen and I think the upper nut is fixed and wont come out and I want to unbolt the shift rod bolt at the powerhead which I cant seem to find. I need to drop the shift rod somehow inorder to replace the waterpump housing and metal plate. All I can do now is just replace the impeller only. Anyone know how to unbolt the rod at the powerhead?
Model is: E20CRLCOS.
Thanks.
Thanks.
