Re: Lower unit removal 50 hp. Honda
Before you start shotgunning this you will need to determine where the leak is.To do that you will have to pressure and vaccume test the gearcase.The most frequent place for this gearcase to fail is at the driveshaft however you still have the shift shaft,propshaft,bearing carrier,anywhere that you have a mating surface to consider.
