Lower Unit Question
frank buck
1988 johnson, v6, 175 hp. when i put it in the forward gear everything is ok. when i put in reverse it is ok but when i try to accelerate in reverse it seems to jump out of gear a little and i hear a grinding of the gears. any ideas. thanks.
Mike M2
Re: Lower Unit Question
THe first thing to do is to pull the lower drain plug on your outdrive. Drain into a pan so you can see the oil. alook for small chunks,light filings ok.<br />Another thought, maybe the clutchdog isn't engaging completely in reverse. Check the above first, if ok, make sure it is shifting completely into reverse. Remove shifter cble from side of motor and shift into reverse by hand. Run it, if ok, adjust shift cable. If it still does it, it's pretty much an outdrive problem, maybe a stripped clutchdog.
frank buck
thanks. i change grease in the lower unit before thanksgiving and ran it the friday after.a few small filings only ran great. in reverse idle works fine, just when you accelerate is the problem. i will check the shifting cables. is the clutchdog an expensive fix.
Mike M2
The filings should have been visable, but you shouldn't be able to feel them. I'm thinking the clutch dog is slipping when you give it a little gas. Check linkeage to make sure reverse is engaging completely first. A worn clutch dog will do the same thing, is a major job to replace. :(
