2000 130 johny,large v/6 gearcase.<br /> Dhadley(or anyone else),this is a theory of mine with a problem,tell me what you think.During the last few trips last season I started getting a gear noise that I could hear when I slowed down rapidly,not a whinning but more like a ratheting noise.I drained the oil and found normal glitter,but also a few very thin flakes on the magnet(no water also),so I pulled the carrier to take a peek and to my suprise everything looked fine,forward and reverse gears look like new and the pinion gear good to but does have a more polished look to it(the case was also very clean,no more metal fragments).Now the one thing that I found was that the water pump impeller had seized to the driveshaft(a ***** to get loose).Correct me if Im wrong,the driveshaft does have vertical play about1/8 inch,this is normal part of the pinion gear shimming process.I guess cyntrifical force pushes the pinion gear upward until the shims make contact with the upper bearing carrier,now if my impeller was frozen it would not allow my driveshaft to come up all the way(impeller has to float on the driveshaft?)and gear clearance would be incorrect causing noise?Boat goes in in a couple weeks,and Im hoping my theory is correct.Well what do you think!
