Paul_Dublin
- May 30, 2004
- 32
Engine wouldnt go into gear, so I dismantled the lower unit. The lower shift rod is bent at the bottom. <br />I also noticed the pinion gear is worn, but the forward and reverse seem good apart from a few small chips.<br />Clutch dog is good on forward side, but has very slightly rounded edges on the reverse side.<br /><br />Does anyone know what may have caused this?<br />Is it necessary to replace the forward and reverse gear if there are only a few small chips?<br />Would slight rounding of the Dog cause problems engaging reverse?<br /><br />Yamaha 60, 1996, 3 CYL
