Knockerjoe
- Nov 13, 2002
- 38
I have twin 1996 200 Yamaha motors. Recently I had a some skeg welding done on my starboard side motor. The lower unit got very hot so I decided to pressure check my lower unit. I drained the oil and pumped in 14 psi. It immediately leaked down and i could here the air coming out of the prop seal area. <br />Curious, i then tried the same test to the port engine and got the same results. Both motors will holds steady at 11 psi but will blow past the seal any higher.<br />The manual states that it should hold 14 psi for 10 seconds?<br />Also can someone explain replacing the lower unit seals as the manual does not give specific instructions on doing so.<br />Thanks for the help!
