I just finished a lower unit paint job and thought the information could be useful to someone. Here are some pics. I used Moeller Zinc Chromate primer(yellow) 1 Can, 1 can Tempo (Evinrude Sea Drive Silver 1983-1986) Part No. 020462, and 1 can Moeller Clear Coat.
I cleaned it up with a wire brush and simple green, sanded it down with 220,320,400 grit. Used the whole can of the primer on it, then started with the paint and used the entire can...plus a little more. Used #0000 steel wool between coats followed up by a tack cloth. Finished off with about 3 or 4 coats of clear. P.S. Don't try to use every last drop in the paint can...it isn't pretty. Also, the overspray with the yellow primer will leave a powder on everything, so cover up. I recommend a good respirator. I picked up a decent one from Wally World for $20 that worked well. Oh, and I purchased my paint from West Marine. www.westmarine.com
Hope this helps someone.
Good Luck!
Good Luck!
