Re: Lower unit oil won't come out top vent?
Similar experience with same V6 gearcase on a purchased 2.6 engine. When drained the first fall, it came out thick and black, but only about half the fluid amount drained out that it should have been. When I refilled, it only took half the normal amount. The next fall, it came out milky and very black. Time to reseal the case. After the reseal, the case vented "normally" and it took the full amount of oil. My sense is that the last time the prior owner had the case resealed, that some gasket sealer must have plugged some passageway in the lower, preventing the chamber from filling fully with oil. Running with to little oil will overheat the remaining oil in the lower-turning it black quickly and could lead to premature failure. Knowing what I do now, I wouldn't run the case with less than the normal amount of oil. Perhaps time to reseal it and see if it makes a difference like it did on mine.
