1987 Evinrude 4 HP
Model: E4RCUD
When you lay the motor on its side (on the ground) something that appears to be clean lower unit oil seaps from the weap hole on the opposite side from the fill/drain plugs.
This would tend to make one think that water would be entering the lower lube as well, however I can't find any image in the manual that calls out what the weap hole is for, nor what oring/seal would allow lower unit oil to trickle out that port.
I see a oring seal on in the gear case, and that would appear to seal the water around the prop from entering the oil...however nothing to do with oil exiting through that weap hole
I also see the oring that I replaced on the bottom of the coolant pump housing. This (as far as I can tell) seals the water thats being sucked in from leaking OUTSIDE the housing so that it continues up the tube for cooling.
What the hell would allow a lube to leak out of this hole?
(hole just to the 11 oclock position of the prop in this photo of a different motor)
Model: E4RCUD
