Re: lower unit oil capacity?
Piece of cake! Make sure you buy the pump attachment that screws onto the bottle and the lower unit. From there, pump till you get a steady, bubble free flow from the vent hole. Put the vent screw in tight then the drain screw and your done! Then clean up the oil mess off the floor...... Oh yeah, change the fibre washers on the vent and drain plugs also.
