Re: Lower unit oil and full mix.
Your lower unit is factory recommended to take OMC Hi-Vis gear lube.It also recommends that you use Johnson/Evinrude TCW3 two cycle oil in your engine or equivelant.As far as brands are concerned I've used Quicksilver TCW3 in my engine and Penzoil Hi-Vis marine gear lube in the lower unit.
