Hey guys, I am putting the lower unit back together with the upper unit (mc-1) in my 78 mark twain 898. Now when I put it back together I rotate the shift shaft clockwise while rotating the prop counter clockwise, it locks and then when I put it together I make sure that the boat is in forward gear. To my knowledge now the lower unit and upper unit(boat) are both in forward gear.
Now I also notice that when I rotate the prop forward (clockwise) while in forward gear it takes a bit of effort (not too much) then it makes a really loud clicking sound.
When the upper and lower are seperated when I hold on to the shift shaft in full clockwise and rotate the prop clockwise and it clicks as well. I'm not sure if I am doing something wrong or if this means that my lower unit is bad. I only have reverse, and neutral as well. If you need any more information let me know, thanks!
