Lower unit lube 1953 Elgin will this work?
94bonestocker
I searched through your forums and found that lubriplate 105 is what most people use in their older outboard in the same class as my 1953 Elgin 7.5 horse. But I was wondering if anyone would know if this would be a suitable sub.
I have a boat load of Royco 22 cf Mil spec grease. It's used in aviation as an all purpose grease. Mostly used in landing gear. It's not a big deal to go get a tube of the lubriplate, but if this grease will work just as well if not better, rock n' roll. Thanks!
Here is it's spec sheet:
http://www.lubadmin.com/upload/produit/FichePDF/lang_1/4190.pdf
Multifunctional synthetic hydrocarbon grease.
Manufactured by Royal Lubricants, Inc.
APPLICATIONS
l ROYCO GREASE 22 CF is a wholly synthetic brown-coloured grease, with a
synthetic hydrocarbon PolyAlphaOlefin- (P.A.O) type base thickened by an
inorganic gel.
SPECIFICATIONS
l ROYCO GREASE 22 CF is qualified:
- MIL-PRF-81322F
- DCSEA 395/A
- DEF STAN 91-52
l ROYCO GREASE 22 CF meets specifications :
- Joint Service designation XG-293
l NATO Code: G-395
ADVANTAGES
l ROYCO GREASE 22 CF is especially recommended for lubrication of roller
bearings, plain bearings and fast-revolving devices used under heavy loads and
subjected to considerable temperature variations ranging between - 54?C and
177?C.
l Excellent resistance to vibrations.
l Recommended for ?filled for life? lubrication.
l The specific structure of ROYCO GREASE 22 CF strengthened as it is by the
contribution of leading-edge technology additives ensures it :
- Exceptional resistance to oxidation.
- Excellent resistance to water.
- Absolute protection against rust and corrosion.
- Very good high- and low-temperature properties.
- Very good resistance to heavy loads.
TYPICAL CHARACTERISTICS METHODS UNITS ROYCO GREASE 22 CF
NLGI Grade NLGI 2
Penetrability ISO 2137
- Unworked 1/10 mm 278
- worked 60 strokes at 25?C ISO 2176 ?C > 315
Drop Point ISO 2160 1b
Copper Corrosion ASTM D1478
Torque at ? 54?C Nm 0.41
- starting Nm 0.06
F_R
Re: Lower unit lube 1953 Elgin will this work?
If I was an engineer, I could read those specs and know something. Lacking that, let's just say that the Lubriplate 105 Motor assembly grease is just a bit too thick to pour. Probably thinner than what you are looking at? But would it work? Heck, I dunno. Those gearcases weren't exactly high tech, you know. As somebody around here likes to say, any grease is better than no grease.
