Lower unit hole.....PLEASE HELP!!!
my Lower unit has very small hole on the ridge, please refer to attached picture. although the hole is very small it is leaking oil, can i use jb weld on it, or how can it be fixed?
thanks for your input.
tater76
Re: Lower unit hole.....PLEASE HELP!!!
How in the heck did that happen??? If you are cheap then drain it, clean it well with rubbing alcohol, sand around the area lightly, and JB weld it. However, the proper way would be to weld it. Any good marina could put a small weld on that in a few minutes.
I have no clue how it happened, I just took the lower unit off to replace the impeller and noticed oil slowly dripping. Do you think they can weld it without taking all the parts out? I want it done right and want it to last.
Frank Acampora
You don't give the year. Are you sure that it is not the impact hole for the speedometer on later model Force engines? If the rubber plug in the top of the lower unit is missing, exhaust and spent oil will eventually run down the front cavity and drip out the speedometer impact hole. Smell the oil. If it smells like gasoline it is exhaust. If it smells like sulphur it is lower unit oil.
If it is indeed a perforation into the gearcase, yes, simply fill it with JB weld. FIRST ream it out with a drill so the epoxy can "grab"
bentle
That does look like the impact hole for the speedo.
Its in the right location anyways.
Where does your speedo tubing hook up to?
Year of your outboard would be most helpful.
sorry, its a 1990 90hp force outboard.
I did notice it after i removed the gearcase cover because the there was a crack in the plastic gearcase cover.
So is that hole suppose to be there?
bentle
Is there some small tubing going into the back of the lower next to the shift rod, or is the
tubing connected to a fin that is mounted to the lower part of the transom on the boat itself?
Most likely it is suppose to be there.(Edit) I have a 89 125hp lower, and a 94 120hp lower and both have this small hole for the speedo.
im not sure, i will have to look tonight, but at first glance i dont see any tubing at all.
I also wanted to know if this crack (so i cant screw the screw in) will affect anything, or if i need to figure out how to fix it?
jerryjerry05
There is no speedo pick up on the 1990/90.
If indeed it's a hole.Do what Frank or Bently suggests.
But welding will fix it for good.Drain it before welding.
The cover/seal.You might be able to use a bigger washer to hold it in place.
thanks to everyone who helped me, turns out the hole is suppose to be there, its some sort of drain hole or something.
JB
Please DON'T SHOUT "HELP", TX90. If you didn't want help we know you wouldn't be posting here. You would get better, faster help if you tell us the problem in your title.
http://forums.iboats.com/showthread.php?t=250874
Good luck. :)
