Lower unit gear lube for 40HP Yamaha
Douglasdzaster
I’m new here. Awesome forum. I’m looking forward to the help. I purchased a Yamaha 40 MSHQ 1992. Got it running and now replacing the impeller. Also changing the gear oil in the lower unit. I’ve always used sae90 . I was wondering if I can put a synthetic 80w90? Also should I check the thermostat on the engine if so how often? It’s been in fresh water.
Gears / bearings / shafts are expensive.----A Yamaha dealer would know the best oil to save you some coins.
Douglasdzaster
Thanks for the input folks. I really appreciate y’all. Anyone know about my thermostat question?
Sea Rider
Buy the gear oil whichever SAE Yamaha sells. Will be gook to inspect the thermo condition, if still good can cleant it with a tooth brush, if removing it will probably need to buy a new thermo gasket as the current one may be already hardened.
Happy Boating
