Inside diameter of the gear housing is 4 1/4”.Why not go on the SEI website and see what gearcase models fit your motor, as well as other models? It is likely that V6 gearcases from the late 70's to the early 2000s will fit, but you need to check. You will want to know your gear ratio. 2::1 is most common, but there are others as well.
Do you have the 4-1/4" gearcase or the larger 4-3/4" gearcase?
Also, not familiar with sei website. Can you send link? ThanksInside diameter of the gear housing is 4 1/4”.
Thanks. Is the 4 1/4” gear case the inside diameter of the case?any 2.0, 2.4, 2.5 V6 gearcase from '76 ta way up in tha 2000's will bolt up if same length as yours.. ratio's will be either 2 ta 1's (2.0 150's) or 1.87 ta 1.. except tha 4 1/4 inch "small case" which will be 1.78 ta one.. but they all will fit.................
