Re: LOWER UNIT CAPACITY
I would suspect about 12-16OZ. Remove both plugs drain it, fill it from the bottom, when you have oil coming out of the top, put the plug in w/new gaslet, have your new bottom plug handy,with a new gasket, remove the nipple and put in your plug. You will loose a little oil but that is ok as it allows room for expansion. Clean up your mess and you are done
