I noticed on the port engine that one of the fins just above the prop has a large section of the corner broken/missing. Its just to the right of the zinc tab and in fact you can see the side of the zinc tab where this break accured. Its probably from forlifts raising the boat in and out at the marina and therefore something that can go unnoticed for sometime. A rock or something also could have been flung-up from the prop and caused the crack. Does this need to be repaired anytime soon or can it go sometime untill I have the loser unit off? Also, how difficult is it to remove lower unit on this engine. I've done a couple of Johnsons and even a Force engine but nothing this larger.<br />Gary
