lower unit 40hp swap
andyhugenberg
I had a 1997 force 40 hp outboard that threw a piston through the block. I replaced it with a 1988 40 hp outboard. The lower unit and prop on the 1997 are in better condition on the 1997 than on the 1988. Will they swap out?
jerryjerry05
Re: lower unit 40hp swap
Probably not.The 88 was made by Force and the 97 made with Mercury parts.J
andyhugenberg
Thanks for the info. The lower units are radically different on the outside. Mainly the prop/prop attachment. I am tearing the blown engine down for salvagable parts. All the electricals, steering and power trim connections were identical. I would still like to make a frankenmotor by using the engine from the 88 on the 97 housing assembly or the 88 housing assembly and the 97 lower unit. I may be screwed either way but I am still willing to look at the feasability.
