lower unit 1975or76 Johnson. V-6 how to remove
deerhunter53118
I am trying to remove the lower unit from a 1975 or 1976 johnson V-6,but the throtle linkage is hanging up?Do i have to remove the linkage some how?or should it just slide off?<br /> Thanks and happy boating,<br /> Tim :confused:
wilde1j
Re: lower unit 1975or76 Johnson. V-6 how to remove
Do you have a shop manual? If not, suggest you get one.<br /><br />Have you disconnected the shift linkage? It's the pivot bolt/pin under the bottom carb. Must be disconnected before the LU can drop.
deerhunter53118
Thank you,<br />I will get a maual and try that. :)
deerhunter53118
Thanks,<br />I went to the library and looked it up.<br />Now i got it out.<br /> Thanks again,<br /> Tim
