fd203
- Apr 9, 2006
- 28
just looking for opinion, I have a 20 horse that when running and in neutral the prop turns slowly, not fast and if you apply a Little pressure to it it does stop spinning but when pressure is removed it will spin slowly again, not sure how bad of symptom this is or if this could be normal. also after it is used in the lake lower unit oil is a little milky so Ive been changing it after every use, am I damaging the lower unit to bad by running it this way? as you can tell I am very green when it comes to outboards but am trying to learn all I can. Thanks for the Help.
