Jud Hamblett
- Nov 16, 2002
- 23
Lower Unit – Water coming from small hole
I just changed the impeller my 115 HP Mercury outboard. When I put the ear muffs on and run the engine, the telltale is strong and water comes out the prop exhaust area as normal.<br />However, I also notice water running steadily out a single small hole located on the front right of the lower unit above where the ear muffs go. The hole leads from the area where the water pump is located and appears to be a drain of some sort. The only thing I can think of is either the water pump tube is not seating -but that is hard plastic and would seem to either mate to the tube above it or not - OR the seal on the top of the water pump housing is leaking. <br />I just can't recall is water came out that hole before. Any advice?
