Horigan
- Jun 12, 2016
- 687
Should a closed cooling system have a lower temperature thermostat than a raw water system? I ask because my motor is spec'd to a 160degF thermostat with a raw water cooling system. My boat has a closed system with raw water going through the oil cooler, heat exchanger, exhaust manifolds, and out the exhaust risers. When I got the boat the temps on the gauge would average about 160degF. I replaced the thermostat with a new one as part of a troubleshooting exercise (ended up replacing a manifold and riser) and it now runs 175-190degF. I installed another 160degF thermostat that I checked for proper opening at 160degF before installation and I'm still around 175-190degF. I've confirmed proper flow through the raw water system and pump operation.
I'm pretty sure that running at 175-190degF is okay, but I just wanted to check with this knowledgeable crowd. Is this temp range okay, or should closed cooling systems run with a lower temp thermostat?
