Lower shifting cable on a 1990 omc with a 4 cyl 3.0 motor
kenww
My lower shifting cable is stuck and will not move. Is there a trick to freeing them up? Thank you.
kenww
GA_Boater
ken - Moved this to the OMC forum out of the Mercruiser section.
jerryjerry05
IF??? your cable is stuck then it needs to be replaced.
First, pull the drive and clean the bellcrank area.
Lots of times the crank gets corroded and locks in place.
