Re: Lower Shift Cable/shift assist switch interaction???
The ONLY purpose of the shift interrupt system is to get the drive out of gear when it is running and in the water with a load on the prop.
The lower gears (Both Forward and reverse) have dogs that engage the dog clutch. These dogs are reverse cut so the drive will stay in gear under heavy load, but even at idle, if the shift interrupt switches didn't work it would be very difficult to get the drive out of gear.
What happens when is gear goes something like this.
When you start to put the shifter into neutral there is resistance from the shift dogs, the outer part of the shift cable is attacted to the Y shaped, spring loaded bracket by the shift interrupt switch. When that y plate moves and activates the shift interrupt switch, the ignition is grounded and the engine dies due to lack of spark. With no pressure on the shift dogs, the inner cable then pulls the drive into neutral. When this happens, the Y plate releases the shift interrupt switch and ignition is returned and the engine keeps running.
All this takes a split second and if you really listen close, you can hear the engine drop a few rpm before running normal again.
With an old corroded cable, there is always pressure on the cable and the Y plate will not release the shift interrupt switch. Then the engine dies completely.
The system is NOT designed to work when putting the drive into gear. Even when the boat is out of the water on on muffs it won't operate because there is no back pressure on the prop to cause the resistance.
Hope that makes sense.
